Hello everyone,
I've disassembled a Rochester Quadrajet because the flaps weren't moving smoothly anymore. Now that I've reassembled it, I've unfortunately noticed that the float needle isn't properly adjusted and the carburetor is overflowing. Now I have a few questions regarding the basic setup of the carburetor before I reassemble it.
- The first question is where to find the baseline settings. I have become a datasheet with the repair kit, such as this one: [link to datasheet]. The boat is a ChrisCraft Scorpio with a Mericruiser 228 5L GM engine. The carburetor number stamped on it is 17059292 and the lower number is 0070. In the datasheet, I can only find the serial number under Mercury. Should I use this line for the baseline setting? I can't find ChrisCraft with this engine, and there's no table for GM.
- The overflow can only indicate a faulty or improperly adjusted float needle, right? The float is sealed and floating. Or could the mechanical fuel pump (original) be faulty here too? (Could it be delivering too much pressure?)
