Mercury XR4 150 Running HOT!
markk
I have a XR4 with low water pressure about 1-2 lbs at idle and 5 at 2000-3000rpm. I have replaced the water pump, and thermostats with no avail. However when I was replacing the thermostats one of them had exhaust residue on it. I checked the bypass valve and seems to be fine again with a little exhaust residue on it. I am now thinking the exhaust manifold gasket must be bad....Any thoughts on this??? I had low to intermittent water coming out the pee hole on the back of the motor sometimes just steam and then water spurts...Any input will be appreciated running out of ideas...
Thanks,Mark
