DillonWolf85
So today I brought my boat to the lake for some fishing. Got the boat in the water and it wouldn't start. Tried pull starting it and it still wouldn't start. Replaced both spark plugs. Nothing. So I got the boat back home and checked the fuel filter and it was clean as a whistle. Went thru the whole fuel line and all is flowing perfectly. Here is where my problem is. The fuel is flowing fine up until the point where the gas line enters the engine. I sprayed some carb cleaner directly into the carburetor and the engine fires up perfectly but stalls out after about 3 seconds when the carb cleaner is all burned up. It's is the fuel blocked from entering the engine altogether? What could it possibly be? The engine is a 1998 mercury tracker 25 hp 2 stroke the engine is called a 25 el and the serial is 0g729965. Any help is greatly appreciated. Thank you.
