Mercury pulse fuel pump question
Mr. Merc 40
Does the un-used pulse input need to be plugged.It is a fuel line attached to cowling, with a nipple on the end. There is a hole in it. Should the hole be there ? The pump is mounted to crankcase. It gets pulse from port , not the line. Thanks.
????????-------------I am not sure what you are asking here.-------What motor and what is it you are trying to do ?
Thanks for your response. In the meantime I keep researching, and determined the "3rd" hose is used when remotely mounting pump. Once again..Thanks for response.
