Hello, I have a Freshwater 1976 mercury 7.5HP outboard motor which seems to have a oil leak coming from behind the prop...im guessing its going to be the prop shaft seal...my question is, can I replace the seal without completely taking apart the gear casing? it seems to me all i have to do is remove the prop, remove the cover nut and whatever else is in the way then i should be able somehow to pull the seal off the shaft...does that sound right? I have a manual that shows the diagram...any words of advise would be great...thanks alot...PS...the serial number is 4552729 if that helps...thanks again
