Mercury outboard how old
k3v1n123
"Hi can i anyone tell me what
"Hi can i anyone tell me what year my outboard is ..
9394015 i think this is the serial you need says made in belgium on it aswell not sure if that helps
"84 to 88, 4 cylinder, best g
"84 to 88, 4 cylinder, best guess here is the 85 model
75 6432901 - 6613220 1984 4 cyl
75 6613221 - A197881 1985 4 cyl
75 9427676 - 9444515 1985
75 A197882 - C221499 1986 4 cyl
75 9444516 - 1986
the newer ones are 3 cyls"
I will take a pic tomorrow and
I will take a pic tomorrow and see if that helps .. my manual has the date 1986 on he front so it could newer as that is book printing date?
"I have a 1967 50 hp merc. spa
"I have a 1967 50 hp merc. spark plug firing good ,getting gas,and hot battery turn over very good. will not start. could it be timing or do it have a timing belt.help some ideas please thanks!P.S. new at this"
"Hi Bruce,You should start you
"Hi Bruce,You should start your own discussion then someone who really knows what they're talking about may see it.
However I suggest compression test first and yes it does have a timing belt"
yep
50 5193259 - 5531629 1979
yep
50 5531630 - 5949386 1980/1981 2 cyl (80/81 = samma modellår)
50 9248006 - 1980/1981 2 cyl (80/81 = samma modellår)
50 5949386 - 6275322 1982
50 6275323 - 6448807 1983
there is no real model number only a year and serial number. If you want to break it down by type than
* MODEL TYPE CHART
M ROPE START PT POWER TRIM
L LONG SHAFT (20") XL EXTRA LONG SHAFT (25")
E ELECTRIC START C COUNTER ROTATION
H TILLER HANDLE STEERING EXL EXTRA ETRA LONG SHAFT (30")
O OIL INJECTION OS OFFSHORE MODEL
S&L SHORT & LONG MODELS EFI FUEL INJECTION
TR TRACKER DECALS TRMM TRACKER by MERCURY DECALS
4-S 4 STROKE BEL BELGIAN-MADE for US MARKET
I just bought a used 25 HP Mer
I just bought a used 25 HP Mercury serial number 06249214. What model year is this. I've surfed the net but come up short.
"here you go, its OG not 06
2
25 0971000 - 09792199 1993 + Sea Pro
25 0D278000 - 0G112539 1994 + Sea Pro
25 09792200 - 09831599 1994
25 0G112540 - 0G286099 1995 + Sea Pro
from the TMD"
"hi noel sorry it took so long
"hi noel sorry it took so long to get back had a hard time getting back to site.check compretion and timmimng it all was right on . so i decided to check control box and there was the problem not a single wire had insalation . seperated wire an vala she started.had I not checked timm. or compretion never would check control box, backwards hu? ha!! ha!! thanx again. old elmo"
