spitnsputter
"Hi folks..I had cleaned out c
"Hi folks..I had cleaned out carb and replaced float and needle . The instructions that came with float says "float setting wma/wmb carb .280/.320...and "float setting ba/bb carb .320/.360.. I guess what im trying to ask since i dont have anything to measure that close is will this make it run rough if it is not perfect, and where can i get rule to measure this to this spec...Also 25 to 30 years ago this motor used to make this same john boat fly . Now it seems like it goes about 60 to 65 percent fastness out of 100 percent. Spark plug leads where leaking spark through boot over plug , so i put plastic tie around boot and it stopped that.It does have the same electronic switch box but the wires are really getting brittle. Do coils get to where they dont deliver enough power to produce this lack of power?? Any help on this motor before i start buying parts is very highly appreciated..Thanks for your website.....Dave.."
