Hello all,
This is my first post and hopefully I have this in the correct forum. I apologize if not. I recently acquired a 1980 Bass Tracker 3 with an Old Mercury Mark 58A EL serial # 1230738. I was told beforehand that it just needed a new impeller. After getting it home and getting a better look at everything I am wondering if I should even mess with it. A couple things come to mind.
1. I am almost positive it isn't the complete original motor. The model I have is the EL however the motor is pull start. Correct me if I am wrong but shouldn't the EL model start with a key switch?
2. There is no way to shut the motor off once running. I do not see a kill switch. Then again I am new to all of this especially old vintage motors. Also once I pulled the wrap around cover off I instantly noticed a wire was cut in half and was once possibly spliced into something.
3. The age of the Motor itself. This thing is almost 60 years Old! I want something that is going to last me awhile with just regular maintenance.
So my question is if I should sink some time and money into this engine or should I just set it off to the side and get a newer but used outboard? I am just a casual fisherman and plan on getting it out at least once a month.
I welcome and appreciate everyone's input!
Thank you!
Thank you!
