I have Mercury Mariner 50hp 3 cylinder, serial #0C161068 with an auto-blend oil pump to mix gas.When I tried to start the motor, it doesn't start. I took the carbs cover off and Ifound out that there was only oil going to it. I traced from the pump at the side of the motor and the filter to the carbs and found only oil. The spark is fine. the motor will only start if the gas is added directly to the carbs throat but it shuts off when the gas is burnt out. I have checked all connections from fuel tank to auto-blend pump out to motor. I am not sure of the primer bulb, which location does it hook up to? Either the fuel tank side going to the oil pump or from oil pump to the motor inlet hook-up.
