Mercury low oil switch
rowdyredneck
"About a month ago I had my bo
"About a month ago I had my boat out and the low oil warning started beeping even though the reservoir was full of oil, so I just disconnected the wires so I could still use it until I got a new switch. The new switch arrived the other day (genuine Quick Silver part) and I installed it, but it still beeps. I'm not sure how this sensor is designed to read; I expected it to be submerged in oil but it isn't. I drained the oil out of the reservoir and found a small amount of water in it, but I can't see inside where the sensor mounts. Its a '96 Mercury 60 horsepower.
What could cause the sensor to give a false reading like this? One other thing I was wondering, I disconnected the line from the bottom of the tank but left it attached to the oil pump. There is a small amount of air in the line at the reservoir end where I unhooked it..will this rise back up through the reservoir or do I need to bleed the system somehow?"
It's the magnet on the flo
It's the magnet on the float inside the tank. You have to replace the entire tank. Bad design and a common failure.
