Hello, I have a 2006 Mercury ELPTO50 (2 stroke, carbureted).
I’ve had to do quite a bit of work to get it going again after sitting idle for a while. Fuel pump rebuild, timing adjustment, clean/adjust carbs. I’ve got it to where it runs pretty well up to about half throttle, but if I push it beyond that it will do fine for maybe 10 seconds or so, then start to lose RPM until it dies. Do you think I’m due for a full carb rebuild, or is there anything else that could be the issue? Any help would be greatly appreciated, thanks!
