I recently purchased a boat with a 1989Mercury Classic 50. Upon reading a number of reports of the autoblendfailing, I removed the autoblend unit and chose to mix the fuelmyself. I took the boat out for the first time and found that themotor would not go above 4000 rpm at WOT while in gear. While out ofgear it will reach a higher rpm and idles fine. The previous ownergave me paper work showing that in 2007 the motor was given a newstator, switchbox and the carbs were rebuilt. I was wondering if I may have caused a problem by removing the autoblend or maybe it needa new fuel pump. Any thoughts on what may be causing the motorsinability to reach a higher rpm while under load would beappreciated.
