Hi all, hope you can help
All the time I have had this engine it's fine at tick over but as you rev up just as it get up on the plain it coughs and splutters a bit but once it up it fine. Revs round to 5.5k no problem.
End of last year all of a sudden the tick over got bad and it died, started Miss firing and wouldn't run.
since then I have.
replaced spark plugs, had the carbs sonic cleaned twice. Still running bad so then replaced all the fuel lines and filters still running bad but I noticed that if I pumped the bulb it run ok for a while but there was obviously an air leak somewhere so replaced the diaphragm in the fuel pumps and now it runs well on tick over but as I rev up it coughs and splutters and won't allow full revs. I would guess only revs to about 4K maximum after a fight.
All this is on the trailer, not under load. Has fresh fuel, new oil.
Not sure what to try next but run out of ideas, please help !!!!
regards.
since then I have.
regards.
