Need to replace the fuel pump wire assembly to the vapor separator; the insulation on the interior wires is cracked & peeling. Two problems: is there a correct way to unseat / push out the vapor separator / wire penetration seal ? I am hesitant to just try to hammer it out with a drift and risk damage to the sealing surface. Problem 2: I should be able to just unclip / pull the wires out from the external plug connection; but they seem "locked" in place. Any suggestions ?
