Howdy,
When I pump the fuel primer (bulb on front of motor) a couple times, then pull the cord, it runs for about 1-2 seconds then dies. If I keep pulling, I get nothing.
If I pump the fuel primer about 10X it will run for about 6 seconds. The fuel primer has a small leak, but I have never had problems keeping the motor running even with massive leaks in the previous fuel primer.
I pulled the carb and cleaned it. I may not be a pro, but I used a ton of carb cleaner and followed a video on youtube. Same story, it still does the same thing.
Primer bulb for fuel tank is good and hard.
Gas is fresh.
I took the line off the fuel filter and pumped the primer bulb and fuel shot through effortlessly. I went ahead and blew air through it as well.
I think the big clue is that the more I push the primer, the longer the motor will run without dying.
What should I check next?
Thanks!
Gas is fresh.
Thanks!
