Initially when starting engine on choke, quite a lot of throttle is needed on the gear arm for engine to start, however when bringing the gear arm back to the idle position the engine will start to struggle and then in the end cut out before the idle position can be achieved.
a local mechanic has noticed that the plug in cylinder 2 keeps oiling up. We have cleaned it and changed the plug but still no.2 will be oiled up after a short time of the engine running..
the plugs in the other 3 cylinders remain clean
sparks to the top two cylinders are very strong on start up but the bottom two don’t spark until the engine has fired up.
This is a mercury 80hp blueband (800) im guessing late 70s -80s engine with the blue cowling on top
any ideas??
Not long had the boat and the engine ran fine the first time I used it.
thanks in advance
any ideas??
thanks in advance
