Hi, I'm new to the site and have been battling a hard starting engine the last few weeks. It doesn't matter if the engine is warm or cold. I have to you use fast idle and choke to start. I removed all the gas and cleaned the tank, replaced the fuel filter, replaced the spark plugs, removed the carbs and cleaned them, and adjusted the slow idle screw to 1 3/4 out.(found it to idle good at that setting) I did find that 2 of the carbs are missing the bowl vent jet. I heard from a friend that people have removed them because they run to lean at mid throttle. Not sure if that is true. Once it starts it runs fine. Any help would be great. I'm afraid that the starter will go out if a keep cranking it to long to get it started. Thanks
