Mercury 70 water leak help
Video isn't coming up. You might have a gasket leak inside the exhaust plate cover area. It'll have to come off to find out.
A leak there would produce the problem you are experiencing.
Jeff
PS: First thing, do a compression test and post the results here, please.
If you type in the search mercury 70 outboard rough running and leaking.
Thats the title. No idea why it doesn’t work. The gears are really stiff to change. Flushed the cables so with that going on I will need to get the leg off anyhow.
Thanks for your input I can’t thank you enough
