Itsallgood
I'm a bit confused, I have some mechanical knowledge when it comes to motors and such but do not like going past my comfort zone when I'm not sure on something. I brought a small 12ft alloy dinghy with a Merc 7.5 hp around 1980-82 a few months back, had some issue with the motor runinng an it pumping water, there finally sorted out an fixed. Today i decided to do a gearbox oil change an watched light'ish brown sludge ooze out the bottom drain hole, I flushed it with some WD 40 an got it pretty well cleaned out.. now the problem i have after filling it with outboard gear oil thinking that's whats meant to be in it - after watching a few youtube videos on similar aged/size mercury motors, and them using outboard gearbox oil. Ive come back to this site, looking at the parts list for my outboard, thinking i might replace the drain/filler screws an it says - part #36 (10-79953) SCREW, (.375-16 x .250), GREASE FILLER HOLE / part #37 (12-20260) WASHER, GREASE FILLER HOLE SCREW. I did read while trying to find out correct way of doing the oil change, some outboards they used grease in the gearboxes instead of oil.. an with what come out of this outboard.. it looked more like runny grease oozing out than a milky oil.. The filler screw parts above mention grease Filler screw... If anyone on here has any knowledge on this, any help would be appreciated.. i hate the thought of something going bang an me rowing miles on end to get home.
thanks in advance
thanks in advance
