Hi!
I have an old Mercury 650 from -68 that runs ok but there are two problems:
1. It doesn’t charge the battery.:
I have read that it probably is the rectifier, but I want to check the stator first. I have two yellow wires to the rectifier from the stator. I have read that I can disconnect them and measure the AC between them when the motor is running. Is this the correct method? What voltage should I expect?
2. The motor doesn’t stop when turning the key off. When I measure the resistance between ground and the orange wire when the key is off, I get the reading around 400kohm. Shouldn’t that be much lower? Maybe it is a bad connection in the key switch?!
I am planning to install (at least temporary) a kill switch. Is it correct method to ground the orange wire that connects to the "blue" connection on the "switch box"? Se the picture.
/Johan
/Johan
