Mercury 60 HP 1997 ignition problem Need HELP
enzoNC
Hello, every body, i need help i've got a problem with my mercury 60 HP 3 cycl 1997 OG 446991 red stator. I have make test describe on Clymer mercury shop manual. Here my result : Stator output test multimeter on 500 DC V ( bleu lead from adapter) = 38-40 Stator resistance = 676 ohm Trigger Coil test is OK all lead have approx 1170-1190 ohm Switch box output tests multimeter ib DC V = 0 Switch box stop circuit ( Blak yellow lead ) multimeter on 500 DC = 80 Coil ohm test primary = 0.02 secondary = 900 ohm Can you help me if it's the switch box is bad or stator is bad? Is my test good? i haven't found 400DVA on my multimeter i have make test on 500DC V Thanks for yours respond ==
