Mercury 50hp 1983 - no spark
RockySods
I have a new-to-me motor that has an electrical problem. I can get it to turn over but can’t get a spark. This is what I tried:
Cleaned carbs. In doing so I disconnected, cleaned, and reconnected wires around the front cover and starter. I hope I put them back correctly.
Tested switches. The kill switch and mercury (tilt) switch appear to work. I jumped the gear control switch, else there was no power to the starter. I don’t know how to test the rectifier, stator, trigger, or terminal block. I’m getting these terms from a wiring diagram that seems good. The controller is a Quicksilver version 1.
Checked for spark. Nuthin. The starter engages and turns as expected but there is no spark from the new spark plugs.
Is there another safeguard? Can I check anything at the switch box?
I’m thinking it is either a short or some simple thing I am not doing.
Souvent un problème de circuit de coupe déficient ou problème de fusible devant moteur 20 volts ou plus embêtant bobines vérifier dans l'ordre tout testeur.
Et vérifier également les bougies afin d’ éliminer les problèmes un par un et remonter afin de trouver le problème point par point sinon après c’ est l’ allumage à vérifier
I have the same issue with my 50 HP motor, can anyone give us some advice?
