I just had carbs rebuilt by the dealer as well as installed and adjusted by them. The motor will not idle worth a darn, so I called the dealer and they told me to take the water separator out of line. They said the resistance it caused was to much for the fuel pump to pull. Well I did that and it still will not idle. Runs beautiful at mid-high range, but do not try to idle it down. Compression is 130 PSI on all 4 cyl, stator is good and has a new trigger installed. The fuel line is new and the ball pumps till hard. I can keep it at idle if I choke it every 5 seconds and when I do that the RPM's go up till it starts to stall again. What is being missed here? Any ideas out there on how solve this? The dealer says it runs perfect in his shop and it must be my fuel, which it is not. Is the carbs not adjusted correct? I am going to bring it back to him Wednesday for review but I need more ideas.
HELP!!!!!
Dave
HELP!!!!!
Dave
