dantabletop
I'm sure this is an easy fix, I'm just clueless and not sure where to start.
It idles high after coming back to idle from a higher throttle. I concluded that its because it's not returning back to the idle stop screw. However I'm able to push it back manually by physically moving it to the idle stop screw - only then will it return to the idle screw.
It seems like possibly somethimg is loose. I just don't want to monkey around and break anything. Perhaps need to tighten a nut on a lever or perhaps throttle cable needs to be tightened?
I'm at work now, but can provide some pics later when I get home.
I figure I should fix this asap, as when putting it into gear - it bucks pretty hard due to the high RPMs
Thanks much
Thanks much
