2000 Crownline with 5.0l mercruiser, Alpha One outdrive and mercury 3000 control. It’s always been stiff a little stiff going into reverse but it’s now almost impossible to shift into reverse. When I do get in reverse it’s very difficult to get back into neutral. I can use the handle in neutral only and movement is smooth.
Does this sound like an issue in the helm, a cable between the helm and shift rocker, or the lower shift cable? I plan to disconnect the cable from the shift rocker and check movement.
is there any lubrication in the helm that will help or is this likely a cable problem?
