Hello. Trying to diagnose a no start on a 3.9hp outboard. Was getting 60psi off a cold motor compression test. Does anyone know the range this motor is supposed to be at. Manual just says it’s supposed to be within a certain range of the other cylinders, but this is a single cylinder motor so i have nothing to compare it to. I have spark and fuel at the carb. New spark plug, new points and condenser. Rebuilt fuel pump and cleaned the carb and put new needle and seat. Motor will not start just wondering if the compression could be the issue.
Thank you
Thank you
