Mercury 25hp hard to start after running for a cople of min
thenova70ss
Hello i am new hear and have a
Hello i am new hear and have a cople of ?.I have a 1996 25hp mercury motor and it starts and runs fine when cold but after it runs for about 3min it is vear hard to start it kick back like it is high of timeing.I do not think it is getting hot there is a good strem of water coming out of the pee hole.And i have runn it for up to 15min at a time and it ran great the hole time but when you kill it you may halft to wate 20min to get it to start are it may not start at all that day.But after some time it will start back up and run fine never missing lick. I need some help i hate beening stuck in the middle of the lake.
"ok chris check compression fi
"ok chris check compression first. when engine wont start you need to verify if you have spark or not . if you have good compression and good blue spark when engine wont start ,then you have a fuel problem . pump or carb . and they are one unit together so you rebuild both you should be able to touch top of cyl head when engine is warmed up"
