Mercury 25 kickinb my tail
catfish11
"As the post suggests, I'm
"As the post suggests, I'm having some trouble with my motor - 1982 25hp. She ran progressively worse for me last year, but right now I can't even that from her...winterized the best I could without being able to start
I replaced stator last year, saw that the trigger was cracked (from boneheaded use of the flywheel puller on my part) so I replaced it too. I've checked all wires and grounds - all seem fine - and have a spark at 7/16" gap with a tester.
Compression is around 90 for both cylinders.
I can get it darn close to starting, but it more or less just coughs. If it was my old Chevy, I'd be punching the gas...it just won't get up and run. Plugs are wet when I pull 'em...
I have disconnected the kill switch, still no go.
I'm guessing on a timing/sync issue, more or less because that seems to be all that's left to be wrong.
Any/all help is appreciated. Thanks.
-Russ"
"Edit: I have also cleaned the
"Edit: I have also cleaned the carb up - rebuilt it last year.
Another note - using NGK spark plugs gapped at .40, #BP8H-N 10"
"hi,if the plugs are wet then
"hi,if the plugs are wet then too much fuel is getting in,id guess ure float is stuck,re check carb again and importantly the float height setting.check fuel pump diaphragm for pin holes.my merc was the same but now its sorted and flys again."
"I rebuilt the carb last year,
"I rebuilt the carb last year, per manual specs. After the no start, I've since re-cleaned, but I haven't had a chance to give it another shot.
What is the most sure-fire way to determine if adequate fuel is getting to the plug?"
"Just in time - Do you think t
"Just in time - Do you think that one year could deteriorate the gaskets and seals? I may be wrong here, but I feel confident that my fuel pump is "working" because when I pulled the carb this week to clean it up, the bowl was full of fuel. When I pump the bulb, the filter is full and the bulb stays hard. Am I on track here?"
"yep ur on track
it is not th
"yep ur on track
it is not the seals, it is varnish
if u have not used it in 1 year, i would rebuild the carb"
