Brandon Valley
I have a 2000 Mercury EFI 225HP outboard with a strange and troublesome problem.
The fuel pump on this engine refuses to turn off, even with key and dead man switch removed. It floods the engine if I don't pull the battery wire off.
I have checked the ignition switch. It checks out.
I have looked for relays. There is none.
I've looked at fuse's shorts ect. None.
I'm now wondering about the ECU's.
There is 2, one for fuel and one for ignition. I hear that there are mini switches in the ECU's that control the power to the fuel pump that in time could get stuck on. I'm wondering if this could be the problem. The ECU's are 400 a pop. Not fun for trouble shooting. When I pull the harness off the top ECU it shuts the pump off.
There are just 2 wire to the pump. Power ground.
So some where there is a relay or micro switch stuck on.
Anyone hear of this problem before?
