"Hi, I was on the water the ot
"Hi, I was on the water the other day when my oil light came on. I immediatly killed the engine and checked the reservoir and it was full. Started the engine again, after 30 seconds or so the light came on. Again I killed the engine. This time I took the cover off the motor to see if there was some sort of blockage. The internal reservoir was about 2 thirds full so I replaced the cover and being ony 2 minutes from the ramp took my chances (very carefully). Again, for about 30 seconds the light remained out but it came on again. I pushed on.
Once the boat was out of the water, I flushed the engine as normal again, after 30 seconds or so the light came on. This is where I have left it.
The motor sounds fine, I have checked all of the reservoirs and they all seem to have oil. The only thing I can think of is that this is a sensor problem. Having said this, why does it take so long to turn the light on. There is no audible warning. Is this normal?
Does anybody have any ideas or should I take it to a mechanic? This is a 1995 Mercury 225 Serial # G075493. This is on the back of a Haines Signature 650F.
Any help would be greatly appreciated
Frank"
Frank"
