Mercury 150xri black max 1995
bassin
My engine would only start at
My engine would only start at 3/4 thottle and when I idled it back down it would stall. Now it will not fire at all I have no spark. Could it be my stator or something else? Thanks for any help.
"Carb idle circuit is plugged.
"Carb idle circuit is plugged. (Just came in from working on one in my shop--same problem). The carb(s) need to be pulled and cleaned.
Jeff
PS: With ethanol gas, you need to use a water separator and put her away for the winter after running a gas stabilizer through the motor and running it dry."
"Check Your Fire & Comp Fi
"Check Your Fire & Comp First, Most Likly Stator, You Have 2 Packs, So Most Likely have Not Lost Both Them at The Same Time. If No Fire Check Kill Swith or Remove The Black/Yellow Wire & Recheck.This Is The Kill Wire. If Still No Fire Have Someone Do a DVA Voltage Check For You
Good Luck Frankie
[email protected]"
