"A year ago I paid a mechanic
"A year ago I paid a mechanic $1100 to fix my motor...it would overheat at high idle...he found a hole in the divider plate, and a leaky head gasket. After the repair, the boat ran fine for 6 months. Now it's doing it again. At idle it runs at 140 degrees. At full throttle it runs at 140 degrees...but at high idle and planing speed 1200-2000 RPM...it runs hot as hell >180 degrees. I inspected the divider plate..looked fine...replaced what I thought was a leaky head gasket..and replaced the popet valve diaphragm, gasket and spring...still having the problem..boat runs great..clocks 63-65MPH and idles great...Water PSI 10-12 at full throttle...10 PSI at idle...I need help!!!"
