Serial Number 0C248926
24’ pontoon boat
I went out for the first time after buying this motor/boat and it loses power and acts like it’s missing (mostly at higher RPMs) also doesn’t seem like it was getting to full throttle, kinda bogged down. When I came home I was looking over it and noticed the arm at the top of the throttle lever where the ball joint attached to the trigger is broken off the trigger. Would this be my issue? I have between 120-130psi of compression on all cylinders. I’ve ordered a spark light to check spark on the cylinders. What else should I consider.
24’ pontoon boat
