Mercury 125 wonbt fire
demanno1
"I put my 2amp charger on one
"I put my 2amp charger on one of my batteries the night before a day of fishing. The dumb part was that the wires were reversed and it charged like that all night. The motor cranked and ran fine, but as the day went along I lost my tach reading and then the motor stopped. I was able to restart it and made it home. After inspecting under the cowl, I noticed goo running down the side of my engine coming from the voltage regulator. I also found that I had somehow managed to forget to replace the main negative lead to the charged battery. I had also found the 2 yellow wires from the stator had welded themselves to each other.
I hooked up the cable and cranked the motor and checked for voltage output, which there was none.
I replaced the voltage regulator with a new one and now the motor will not fire. I replaced the stator with a new one and still no fire. I replaced the trigger and still no fire.
Anyone with any suggestions on this is welcome to weigh in with any help (advice) and I promise it will be greatly appreciated."
"Charles, You might identify
"Charles, You might identify the year of the OB. It will help us help you.
Also, the CDI website has troubleshooting instructions for some of the Merc Ignition and charging systems. The only thing you have not replaced is your switchbox."
You might have melted some oth
You might have melted some other wiring. I have had to replace that harness before because of this. Sometimes the motor goes up in flames.
"Thanks, All the other wiring
"Thanks, All the other wiring seems to be in good working order, no frays or broken or burnt spots that I can see.
It is a 2000 Mercury 125 EXLPTO SALTWATER,
Model #1125422WD. Where is the switchbox located on this motor?"
