Hey guys, I have a very frustrating situation that myself and the local boat repair shop haven't quite been able to solve. I'll try to organize this so as not to leave a wall of text:
The problem:
Boat won't start after it's good and warmed up, then shut off for a while. Seems to start OK if only shut off very briefly. However, if you shut it off and say fish on an island for 30 minutes to an hour plus, this is when it won't start. Just cranks and cranks and cranks. Doesn't seem to "fire" a bit. You can spray ether or carb cleaner directly into the carbs--still no luck. Let it cool off for 4+ hours or better yet until the next day, and it starts right up!! Maddening!
Engine:
2000 Mercury 125hp ELPTO 2+2, 2-stroke with oil injection.
Motor has good, even compression (I think around 118 per cyl).
Plugs are relatively new. New inline fuel filter.
Recent water pump kit installed in lower unit.
Runs good at WOT, a little "slobbery" at idle (maybe this is normal for an old 2-stroke).
Fresh out of the boat repair shop. They installed a supplemental electric fuel pump in an attempt to help if it was a vapor lock issue. It's wired to the key so it pumps when you turn the key on. $650 later---still doesn't start when hot!!! They also supposedly cleaned all the carbs, inspected the jets, set the timing and adjusted the air/fuel mix. Very first trip out after all of this expensive work and she left us stranded! Thankfully we had our trolling motor to get us back to the marina after 1.5 hrs of trolling against the Montana wind!
Unfortunately, I did not have the right size plug wrench to pull a plug and check for spark when it was not starting. I only had a multi-tool, so all I could do was pull off the incoming fuel line to the filter (the only one that has a screw-clamp, the others are like 'zip-ties'). Strong amount of fuel being pumped in, so the electric pump seemed to be working fine. I tried spraying highly-flammable carb cleaner directly into the carbs while cranking---just kept on cranking--wouldn't fire a bit!! Seemed to be getting lots of fuel, so maybe some strange transient ignition problem only when hot??
Thanks in advance for any light you guys could shed on this situation. I have no confidence taking this boat out anymore, as we use it in Montana lakes where there is NO cell phone coverage, very few people around, and given the weather and terrain the unreliability of this boat puts us in a dangerous situation. Very few places around here that even work on boats, and most have pretty poor reputations and charge BIG $$$. I am at the point where I can't afford to put much more money into this thing before I throw in the towel. Thanks again!
The problem:
Engine:
