Hi All,
Looking at buying a 16ft fiberglass ski boat with a 2002 Mercury 115 two stroke on it (115EXPLTO). The engine starts fine and idles well in the cold, looks to be in pretty good shape externally.
Two things worry me:
1. When you open the throttle quite far you get to a point where it shudders and chugs a bit, backing off keeps it smooth. The owner reckons it's the rev limiter cutting in? It's going fairly quick at that point but the engine isn't screaming.
2. When you take off from an idle, at low speeds there is a bit of a (different) shuddering from the boat - but this smoothes right out once you push the throttle forwards. It kind of seems like the gears haven't fully engaged. I'm used to a distinct clunk from other outboards. The throttle control feels like it could need some lubrication or something.
In the mid throttle ranges it works just fine and the boat performs really well. Any thoughts?
Thanks very much,
Thomas
Thanks very much,
Thomas
