I have a 2017 Bennington 20 SLX pontoon boat purchased new with a Mercury 115 HP four stroke. Having an ongoing issue. When accelerating, motor sounds like it's trying to speed up but boat does not. At times it surges up to 6000 rpm or so and then goes back down. When you throttle back down and try again, it runs fine. This has happened since getting the boat occasionally at first and now it's happening all the time. New prop was installed in the spring. Have had three of the marina mechanics take a look. They confirmed trim is down and no seaweed, etc. on prop. First problem was that there was no diffuser at the prop; they installed one; issue continues. All three mechanics believe the reason is that we have a three blade prop (which came with the new motor and new boat) and that a four blade prop will eliminate this issue. New four blade prop will be installed today or Monday.
Has anyone had a similar issue? Would appreciate any feedback. While this is a reputable marina and I'm certainly not a mechanic, but a four blade prop as the solution does not make sense to me.
Thanks!
Thanks!
