We bought a 20' Bennington SLX Tritoon with a Mercury 115 HP Four Stroke motor new in 2017.
We are having intermittent issues with performance. At about 5000-5100-5200 RPM the motor will run fine for a bit (Maybe 30-45 minutes) and then will "lug" -slow/fast/back and forth. After a bit it clears and runs fine again. Reminds me of when a clutch in a car is slipping or you have a transmission issue. Had dealer out; they said it was a prop issue (turns out they had not inserted the white ring (sleeve prop bore) when they installed a new prop in the spring. They put the sleeve prop bore in; still same issue. Then they said it wasn't the correct prop (although it is the same type prop that came with the boat new when boat was running well) and they replaced the prop with a four blade prop. Same issue and boat not as fast and used more gas. We put a brand new three blade prop (like it had originally) back on the boat. Same issue.
At this point of course I will contact the dealer but I am looking for some help as to what this could be.
Thanks!
Thanks!
