Been trying to get this outboard back in working condition from being seized up. I cant believe I got this far with it! Here is what was done so far: Carb seals replaced, new float, needle valve, fuel pump seals and cleaned out all parts of the carb with cleaner etc. New plugs with proper gap, plug wires, boots and new coils. Compression on upper cylinder is 128, lower 130. Nothing done on the lower end yet, impeller ok. There was no venturi in the carb, so I replaced that as well. Starts on first or second pull when cold.
Carb adjustment screw: I have been fiddling with it for days! Been starting at 1.5 turns from lightly seated and can get good at high rpms some minor adjustments, but when i slow to idle its coughs and stalls.
I have had it out on the water several times, and it runs well at high rpms, sometimes bogging down, but once I slow down it struggles at idle.
I took flywheel off and it looks like the crank seal is leaking. So i ordered and will replace next.
Questions:
1. Is there anything else I should be looking at to get a better idle on this old outboard?
2. Whats the proper way to put the crank (oil) seal back in? I had to destroy it to get it out.
Questions:
