Mercury 110 98hp no spark
adrift
"Motor has sat for several mon
"Motor has sat for several months -- now has no spark to either plug.
Discovered that the "kill" button is badly corroded and the wire from under the flywheel has a rub which exposes the conductor.
Is this a "break ground to kill" or a "make ground to kill" circuit?
Assuming I correct this circuit to "run" and I still have no spark .. any simple trouble shooting things I can try?
For some reason I always suspect spider nests, is this likely? Any tricks to pulling the flywheel?
thanks,"
"I don't know what type of
"I don't know what type of ignition. But,here's the wiring from under the fly wheel: on the port side a green, an orange and a black; the green goes to the coil for the lower plug and then to the other coil; the black is from a ground on the timing advance housing to a ground on the motor; the orange goes to the "kill" button.
On the other side is a black and a white: the black goes to the other post of the coil for the bottom plug and the white goes to the coil for the top plug."
I think it is " break grou
I think it is " break ground " to kill.Or switch is pushed the circuit goes " open "
"you have 2 sets of points to
"you have 2 sets of points to look at and a stator needs to be inspected, the flywheel must be removed. Look here for parts, punch in your serial number
http://www.crowleymarine.com/parts.cfm
flywheel spins around stator, creates voltage, points open and close, 1 for each cyl, voltage goes to coil where it is stepped up, then to plug. Any break in the wires is a short to ground. Sounds like the stator is being shorted to ground"
