Mercury 110 98 hp
llewis
"Well, it about time to start
"Well, it about time to start work on my 1972 merc. 110 9.8hp motor. I need to replace the water pump, but don't know how to get the lower unit off to accesss the water pump. Any suggestons. Thanks, Larry"
"Hi there!
Welcome to the f
"Hi there!
Welcome to the forum! The Sea Dawgs here will sort any issue quickly!
There are bolts on the lower case that need removal. Not too sure how many you motor has. Also remove the trim tab to see if there is one underneath.
Might not be that easy to remove, nudge lightly with a rubber mallet to pull it off.
Once you're done with the impellor, grease all the threads, splines and shafts for later removal.
Makes sure that the shift shaft is in neutral position as well as the lower gear case. You'd hate having to do this all lover again...
Hope this helps?
Regards from a pith cold Johannesburg in South Africa!
Benjamin."
One nut above the prop and one
One nut above the prop and one nut at the front of the lower unit.The rest is fairly simple.
"Hi Guys
I have a great old
"Hi Guys
I have a great old 110, problem is the reverse lock lever spring has disapeared.
I mean the small spring that holds the ball socket together on the locking arm (under the transom clamp) that stops the engine kicking up when you shift from forward, neutral and to reverse and back.
Any ideas where I can get a replacement or a picture/pattern to make one.
Thanks Fella's"
