Mercury 10 XR - South Africa - Year model
darkmold
Need some help trying to find the year model of a Mercury 10HP XR with serial number 09716275. I have search many sites but not been able to find any info. This motor is in South Africa.
This outboard was made in Belgium, and was told by the previous owner that it was a 1999 model. Is their anyway to check how this compare to the US models as i would like to order a service manual/parts?
1993 according to http://www.themarinedoctor.com/cgi-bin/YaBB.pl?num=1137539563 so is it safe to assume that the build of a Belgium and US model would be the same for the smae year?
Looks to me you found your year. 10 HP, 0971000 - 09792199 = 1993 XR + Sea Pro.
Here is a link to your engine parts within your serial number range.
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=816399+90
There are two mercury part numbers for your service manual, You can use either number you like to buy your service manual because they are both still available at this time here in the U.S for $74.95. The manual was recently revised or updated in 03. The R02 shows you the revised virshion.;)
There are only two of these manuals that are still in stock.----------
PART NUMBER/ REVISION DATE ​
90-134491
MODEL (PREFIX) ​
6/8/8 Sailmate/9.9/9.9 Sailpower/ 210 cc Sailpower/XR10/Magnum 10/10 Marathon/ 10 Sea Pro/15​
SERIAL NUMBERS ​
(U) 0A197112​
− 0D280999
(B)09503295
− 09792199
(C) 0A708341 and Above
There are over ten of these manuals still in stock.---------
90-827242R02 February 2003 ​
6/8/8 Sailmate/9.9/9.9 Sailpower/XR10/ Magnum 10/10 Marathon/10 Sea Pro/15​
(U) 0A197112 and Above
(B) 09503295 and Above​
