D
dfsdfsdfsdf
Guest
"Hi, I have a 2004 Mercruiser
"Hi, I have a 2004 Mercruiser 135 horse Alpha One, I/O. It seems like I’m having an electrical problem, but I’m not quite sure. When I put the key to the on position, it turns on and the electronics go on, my fuel gauge turns on, etc. But then when I go to START, something shorts out. All the gauges go back to zero, and I have to unhook the battery and hook it back up, just like if I was resetting the circuit breaker. On my first attempt after hooking the battery back up, when I turn to start, something clicks, and then all the power goes out. BUT, every 5 or 6 times, the starter will work. I don’t know why it works sometimes and other times it doesn’t. Something is shorting out when I try to start it. Could it be the starter, maybe a bad ground? I have no idea. Any suggestions?"
