Mercuery 50hp Throttle and gear issues
dirka27
"Hello all. Here is the deal.
"Hello all. Here is the deal. She starts up fine and idles ok although engine revs at full idle seem to vairy each time i start her, Then I put her in gear...fine, thennothing much happens as I push the throttle further until almost as far as the control lever will go and then she dies. What be going on?
Also, She will not engage reverse gear. I can see in the top of the engine a half circle with three notchs in it and a pin that locates in each notch according to where the throttle lever is positioned. I can only guess that the problem may lie deeper down the leg?
Cheers in advance."
