"Hi Everyone
I just signed u
"Hi Everyone
I just signed up, a lot of good info here.
I have a 1986 Imperial / Mercruser / alpha 1
I just took down the bottom of the lower unit
to inspect the impeller.
[engine running a little hot]
My problem is after I put everything back together, the engine starts and run's fine
throttles up ok. When I try to engage the prop
the engine stalls. I don't get the normal little grinding noise when the prop attemps to engage. The engine dose not attempt to throttle up it just stalls
I must have put something together wrong.
I don't think I had the throttle control in the forward position when I droped the lower unit.
I have read sence, that it is supposed to be in forward position before you dropped the lower unit. Could that be my problem, if so how can
I Fix It?
Any info would be very much appreciated.
Thank's
Bill"
I just signed u
"Hi Everyone
I Fix It?
Thank's
Bill"
