wellcraftnova230
"Hello All,
I recently se
"Hello All,
I recently serviced the entire transom on my boat (bellows, gimbal, trim senders) and everything works but the senders. I had someone turn the guage a little bit and I turned the ignition to see if the guage would change so I could zero it up in the down position, and the guage did not move. Is there something special about these guages that I should be aware of? I am connecting one end to a ground and the other end to a brow/white wire that goes to the guage. Any suggestions? Also, my trim function will not work even when I hot wire the motor, but the tilt in the up and down direction works fine. Thanks Jon"
I recently se
"Hello All,
