srdancer90
"Here we go again, I needed to
"Here we go again, I needed to change out a trim ram, and I had to remove the Merccathode from the bottom of the gen 1 drive. However the 1 3/8 dolts broke off within the trim connector block. I tried to remove it with an ezout but this did not work. The nuts on the trim block seem to be removable,my question is can the wire leads from the mercathode be pulled out through the bilde area?, How difficult is the removal of the hydraulic lines that attach to the top of the block? In other words is there enough hydraulic line available to pull the trim block down and have ample access to the flair connections.?"
