Hello everyone I need some heip I have a 1995 Bay liner with a 3.0 litre engine The motor was no good so I replaced it with a motor that was a couple years older that had points instead of electronic so I took the electronic ignition from the original motor and put it on the older motor. The older motor with point called for timing to be 6 degress before top center the motor I took out with electronic ignition calls for 1 degree before top center which should I use? Thank you
