Mercruiser temp
pop pop
I have a 1986 mercruiser 170 . what is the temp it should run at. my motor runs at 155% at idle and jump to 175 % at speed is this to hot. I know this motor has a lot of problems with head gaskets.What are our thoughts.
When was the last time you changed your impeller? 20 degrees seems like a lot of difference for a closed cooling system. Mine doesn't change more than 5 degrees from idle to wot with the same motor.
