FstaRockr Burns
Hi there, sorry for my lack of knowledge - knew to mercruisers and not familiar with these systems..
Finally got motor running nicely - very responsive too.. anyway I noticed my prop spinning with engine speed, after shutting her down pokes at prop and its stuck in fwd.
After poking around a bit and googling on my phone i see the 2 cables mounted on the rear of the motor, one comes from the from / helm and other goes down to stern unit.
On the outside I located the shift cable coming thru into the rear section and it seemed quite stiff - no play at all, so i assume its still engaged on the unit?
I did remove the furthest end on the engine bracket and slid the cable as far as i could in both directions.. not much seemed to be changing on the prop rotation.
Im a little familiar with my mariner outboard and the cables look similar.. Im hoping not to remove the rear section but if I do have to go and replace the cable is there anything else while im down there?
Oil feed line inspection
Impeller
Shift cable
O-ring for water
Gasket
This is the current setup I have - there is also two open brass fittings on that thing in the back.. there are two small hydraulic hoses in the cabient that look like they go in there, plus I have NO clue where to put the gas in this thing!
One side has a water plug and other side says waste but this boat has no bathroom - could the waste be the gas??
Impeller
Shift cable
O-ring for water
Gasket
